Alternative rear caliper for 3TJ
oldgreg
Post by oldgreg » Fri May 23, 2008 9:35 pm
Hi all,
Anyone know if there are any?
Cheers,
Graeme :)
Re: Alternative rear caliper for 3TJ
Post by Evilchicken0 » Fri May 23, 2008 10:27 pm
I think it's a standard brembo unit used on a lot of bikes, have a look at the Ducati range about 748 / 916 time ... maybe 999 style.
But then again if it's for a road bike you know a 3TJ caliper will fit so look for one of those first.
oldgreg
Post by oldgreg » Sat May 24, 2008 12:14 am
Ducatti you say, hmmmm.....
Just having a bit of trouble finding a 3tj one in good condition for cheap (skint. again. :roll: )
Post by Evilchicken0 » Sat May 24, 2008 11:28 am
If your skint then it might be best to buy the proper one ... then you'll just buy once.
I thought the rear caliper from a fzr600 would fit the 400 3en2 ... but the body just touched the disk cos it was a smaller dia. It was ok after it was filled down though.
oldgreg
Post by oldgreg » Sat May 24, 2008 12:08 pm
Sound advice me thinks.
Typical really. I spend all my pennies on a shiney new front end, and within a week or so my rear caliper seals fail :x
Ah well. I'll just have to keep repeating the motorcycle modifiers mantra "its not about the money, its not aout the money" :lol:
Post by Evilchicken0 » Sat May 24, 2008 12:24 pm
Why don't you replace the seals ???
It's not a big job and only two seals shouldn't cost much
oollit
Bike owned: FZR400RR 3TJ, RF900R
Post by oollit » Sat May 24, 2008 1:29 pm
Wemoto do 3TJ rear calliper seals for £8
They also do a stainless steel piston and seal kit for £38. I fitted one of these kits to my 3TJ last year and i have had no problems so far.
http://shop.wemoto.com/index.dyn
I only please one person per day.
Today is not your day, tomorrow isn't looking good either.
simmo
Bike owned: nc30 road & zxr400 race
Post by simmo » Sat May 24, 2008 3:43 pm
you mean people actually use their rear bake :?
i have to keep striping the rear brake on the er5 cos it seizes up, i had to buy a new rear caliper for the vfr cos that seized solid, bin like that for a about 6 months :o , and i think ive only touched the rear brake twice on the fzr, just to see if it worked. lol
i know i should really use it but for some reason i just never get round to using it.
oldgreg
Post by oldgreg » Sat May 24, 2008 8:44 pm
I replaced the seals when i fitted new pads about 6months ago, noticed that the pistons were quite badly pitted when i did that but hoped they'd be ok :oops: Its started weeping brake fluid though so i guess i was wrong!
It'd have to be a piston kit, but my caliper is in a such a sorry state looks-wise i'd rather replace it with something thats in better shape :)
