New clutch cable at the end of its adjustment already ?
royster81
Post by royster81 » Tue May 20, 2014 1:02 pm
I'm only after fitting a new aftermarket clutch cable to me bike and I think it's at it's maximum length already,has anyone any experience of this before ?
mattUKNC
Re: New clutch cable at the end of its adjustment already ?
Post by mattUKNC » Tue May 20, 2014 2:55 pm
At both ends?!
royster81
Post by royster81 » Tue May 20, 2014 3:24 pm
At the engine end the nut is right on the edge of the threads, the lever end is fully in but I thought it was for fine adjustment, there's a little bit of freeplay but that disappears when I wind the lever adjust out.
mattUKNC
Post by mattUKNC » Tue May 20, 2014 3:45 pm
I see, sounds about right to me. My lever end is about 1/2 way out, easy to see why the clocks get messed up! :)
VFRkieran
Post by VFRkieran » Tue May 20, 2014 11:21 pm
Ive found this with a new OEM cable, right at the end of its adjustment from the off. Seems too long to fit properly too.
Post by Neosophist » Wed May 21, 2014 7:05 am
VFRkieran wrote:Ive found this with a new OEM cable, right at the end of its adjustment from the off. Seems too long to fit properly too.
funny enough i bought a new cluch cable from Honda and its miles longer than the old one you have to route it funny or it sticks out..
i took it off and fitted a 2nd hand one i have knocking around, still have the new one, put it back inthe bag
VFRkieran
Post by VFRkieran » Wed May 21, 2014 2:05 pm
That's interesting, I thought it was just me being and idiot not routing it correctly but sounds like this could be an issue with them being manufactured too long.
Post by Neosophist » Wed May 21, 2014 4:31 pm
Yes, I was going to chase it up but i gave up with it, bikes forsale too so doubt ill ever do anything about it.
royster81
Post by royster81 » Fri May 23, 2014 6:35 pm
Neosophist wrote:Yes, I was going to chase it up but i gave up with it, bikes for sale too so doubt ill ever do anything about it.
Neo your selling the VFR ? the one you fished out of the rice field ?
i initially thought since it was a pattern part that thats why it didnt fit properly,but i'm glad to see i'm not the only one, i'll ask rick if hes came across it and is there a way to fix it or get around it.
Acid
Bike owned: Rs125 Nc30 Cr500 Sm
Post by Acid » Tue May 27, 2014 4:12 pm
I had this problem too, contacted ebay seller and they sent me another one and it fitted fine.
it was a pattern part tho and not oem.
