Anyone know what this part is?
ianw
Post by ianw » Tue Sep 18, 2012 9:42 pm
Found a bundle of insulation tape connected to a black/green/brown connector coming off the clocks whilst searching for a solution to my not getting a spark.
Unpicked the 'orrible tape and found this knackered lump of electrics inside:
Can anyone identify it? I think it looks like the speed limiter according to the wiring diagram. It's in 2 pieces and the circuit is broken. Not sure if it's a problem or not, whether it's causing my starting problem or not, whether it needs replacing or just binning.
Any ideas?
amorti
Regular Member
Bike owned: CB-1, MSX125
Re: Anyone know what this part is?
Post by amorti » Thu Sep 20, 2012 4:00 pm
ianw wrote:Found a bundle of insulation tape connected to a black/green/brown connector coming off the clocks whilst searching for a solution to my not getting a spark.
Any ideas?
Smallest pic in the world but I do think it's the limiter. It gets removed like this so the disc never breaks the sensor and the bike never knows it's going above 180km/h.
You can also just as well fit a resistor, same difference really. Someone knows which spec, or just measure the resistance across black and brown and get a suitable resistor to match.
ianw
Post by ianw » Thu Sep 20, 2012 7:59 pm
Strange, it should enlarge when you click on it, I'm sure it did when I first posted. Oh well, lets try again...
http://postimage.org/image/sc2a2wah3/
I disconnected it completely and took it out for a blast lastnight. Doesn't seem to affect things much, but didn't get chance to go flat out in top so still not sure if its limited. Revs freely up to 15k rpm anyway.
I was concerned that it might stop something working all together... apparently not.
