cbr400 nc 23 aero fork help asap !!!
- Bike owned: cbr400 nc 23 aero Project
hi guys im in the process of replacing the fork seals on my aeros fork legs Ive removed the cirlcip retaining the seal and removed the alen bolt form the bottom of the fork leg how ever the forks wil not still separate form the sliders any body able to point me in the direction of how to go about this please , many thanks ben
Re: cbr400 nc 23 aero fork help asap !!!
please somebody if it helps ill try explaining it in non gerbosh like i wrote last night lol , the issue being is i cannot get the fok sliders away frim the fork legs even though i have removed the retaining bolts under each leg, and removed the cirlips on both legs that retain the seals i can hear something sliding up and down inside the leg but it will not fall out , also if it makes any difference my forks air the air pressured one , here as if i belve right the later tri arm and gull arm use full on hrdrolic set up ?,
do not mean in anway too sound cocky and sarcastic i apriacte all you guys on here for your wealth of knowledge , im jsut desprate to get the new seals in so i can start building the bike back up bit by bit lol
cheers
Ben
cheers
Ben
Are you doing it properly? With the tube fully inside the slider you pull it out quickly so that the bushes strike the oil seal in a hammering motion. Keep doing this until it's out.
Wozza wrote:Are you doing it properly? With the tube fully inside the slider you pull it out quickly so that the bushes strike the oil seal in a hammering motion. Keep doing this until it's out.
ah ok mate thank you will go try this now
wozzza you're a legend got one side out other is being a little bit difficult lol but hey ones out ill attack the other one again later, thanks again buddy you're a legend and i owe you one
It might help to clamp it in a vice. Clamp the slider (lower) not the tube, and use a couple of bits of wood to prevent damage.
Wozza wrote:It might help to clamp it in a vice. Clamp the slider (lower) not the tube, and use a couple of bits of wood to prevent damage.
yeah thanks for the extra tip there bud i also found it helps if you remove the other Allen bolt out the bottom as well lol luckily didn't damage the forks so all good once again thanks for your help mate , one other question though i wanted to start a thread for my project do i do it in the cbr section or general members bikes pictures ?
I think you need to be a site supporter to post your own thread in the members' bikes section. It's £10 for one year - if you don't want to do that then just put it in here.
HOW DO I BECOME A SITE SUPPORTER AND PAY MY £10?
