fuel tap positions
ibby4585
Bike owned: SP's
fuel tap positions
Post by ibby4585 »
hi, could someone clarify fuel tap positions on a nc30 please?? (please dont call me a thick twat under your breath!!)
tomski
Re: fuel tap positions
Post by tomski »
From memory;
Theres a marker on the fairing just above the tap, labelled fuel.
As long as your tap is standard, just line up the positions (ON,RES,OFF) labelled on the tap to the marker on the fairing.
Simples ;)
paul nc 24
Bike owned: 2000 R1
Post by paul nc 24 »
twelve o'clock = on
three o'clock = off
six oclock = res :up:
(thick twat) :shock: hope you didn't hear that :pmsl:
ibby4585
Bike owned: SP's
Post by ibby4585 »
very simples!! many thanks. i did hear that by the way!!
Sligeach
Post by Sligeach »
the tap has a long lever and a shorter lever, the shorter one pointed toward 12oclock is normal fule flow, the longer one pointed toward 12oclock is on reserve
ibby4585
Bike owned: SP's
Post by ibby4585 »
jesus thats 3 different answers now!! thought it was meant to be simples :shock: !!
paul nc 24
Bike owned: 2000 R1
paul nc 24 wrote:twelve o'clock = on
three o'clock = off
sorry ibby :oops:
:spank: :spank: :spank: :spank: :spank: :spank: :spank: :spank:
who's the thick twat now me :oops: :oops: :oops:
and you dont have to keep it under your breath!
i had been reading nc24 tap problems before reading your post :oops: :oops: and now im off to stand in the corner with my big D pointy hat..........AGAIN!!!!!. :wanker:
neurosyndrome
Post by neurosyndrome »
Sligeach wrote:the tap has a long lever and a shorter lever, the shorter one pointed toward 12oclock is normal fule flow, the longer one pointed toward 12oclock is on reserve
Isn't it a bit stupid???
Because if you need to put the tap on "res" when you're riding, you have to pass through "off", no? :whistle:
Isn't it a proble at 100 mph on a track? :scare:
It sould be but the carbs have a fuel supply in them so a small disruption in fuel form the tank is on worries.
try turning your fuel off next time you are out - it takes a good few seconds to start to pass out...
neurosyndrome
To sum up, and also to add some pictures :grin:
Can someone confirm the following pictures, please? :
Res?
Off?
On?
If you're blind, here are the links :ninja:
Res : http://img340.imageshack.us/img340/6044/resq.jpg" onclick="window.open(this.href);return false;
Off : http://img517.imageshack.us/img517/5413/offgr.jpg" onclick="window.open(this.href);return false;
On : http://img517.imageshack.us/img517/6338/14749763.jpg" onclick="window.open(this.href);return false;
Cheers,
