NC30 Dog bone Mod, Urgent!!!!!
				Spike16
Urgently need, tried doing a search but not much found
how far down the original dog bone should I drill the new hole?
need to do this today as Il hopefully be at oulton tomorrow and dont want to be decking the fairing out again
Re: NC30 Dog bone Mod, Urgent!!!!!
mate, seeing as it is my fault due to lack of postage skills... I'll post these pics for you.
Cammo knows the answer>> My recall is that it is 8mm? You end up with a slot rather than 2 seperate holes.
Hope this helps dude..
				Spike16
slot? shit so wont the dogbone move about in the slot?
got a pic of a modded one
Who me?!CMSMJ1 wrote:Cammo knows the answer>> My recall is that it is 8mm? You end up with a slot rather than 2 seperate holes.
8mm is correct.
You do end up with a slot. Best to weld up the old hole and drill a new as they do overlap a smidge.
				Spike16
no time to weld, is it ok to run with this slot? or will the triangle thing move about in the slot
				hunter
This what you want spike,
http://www.400greybike.info/newforum/vi ... =24&t=5346" onclick="window.open(this.href);return false;
If you imagine drilling 8mm from the centre of the original hole you'll get a hole with one edge missing (form the other hole)
It "may" be fine, as I am sure that only a few people have welded it up. If you want, you could go for a 10mm hole for even more ride height..and avoid drilling into the other hole.
I have no pics to hand..I'll see if I can find one.
@ Stickshift..yeah you!
				Spike16
no time, Iv adjusted the chain so its giving max ride height but not drilled dog bone
Spike, try and get it done for next time out.
It changes the handling for the better and also the shock if you have a standard one. In standard form nc30's drag their arse way to low to the ground for decent tip in on the track.
