These are tiny and carb cleaner won't shift the shit out if that green muck has been allowed to dry in there.
Compressed air and ultrasonic cleaning may be the only way to go.
Just had a thought, have you checked the idle adjustment screw?
Its underneath the carbs , it is a plastic knurled nut accessed from the lefthand side of the bike as you sit on it, bit fiddly and you can get a bit of a burn if the engine is hot.mykel49 wrote:Ok so where is the idle adjustment screw ?
However, I'm not a 100% sure it is still blocked jets etc.. it's like when I turned choke down to halfway the engine was idling so low it should have stopped anyway, if that makes sense!! so maybe it is the idle adjustment screw, I will adjust that today. Thanks also to Superjack for advice on positioning, and all your advice so far, it's much appreciated.dobbslc wrote:Good progress! But I would say that cutting out when you shut off the choke means you still have blocked fuel or air ways in the carbs
Re above - Do you think with my jammed float in carb this is the reason I had fuel getting through to engine oil (smell of fuel from oil ) ?dobbslc wrote: If there is fuel in the oil that means both the tap and at least one carb is letting fuel through.
Defiantly.mykel49 wrote:Re above - Do you think with my jammed float in carb this is the reason I had fuel getting through to engine oil (smell of fuel from oil ) ?dobbslc wrote: If there is fuel in the oil that means both the tap and at least one carb is letting fuel through.
