Rick an Tony save the day!!!! Thank you.
I received an e-mail from Rick. He said to use the TCIP-4 software as well. So, fiorst problem is I was trying to use much older software (Honda-tci).
Rick then said there is a V75 and V80 but he wasn't sure which we had. So, I tried the V80 first and here's what I got.
It says right at the bottom that I have the V75 and the V80 doesn't work. So, I opend the V75 and......
Whallah!!!!!!
So, I have a V75 box. I guess that means I can only program using the V75 software, unless anyone knows how I can upgrade to the latest software in the ECU.
Just for kicks, here's a screenshot of the 3D ignition mapping that I will be able to do as soon as I finish wiring the TPS in. Hopefully that will be done this weekend.
Now, I just have to get to the dyno and start playing with it and see if the maps work and what to do different. As I said in the beginning of this post the HRC map loaded in the box doesn't work like our HRC ECU, so I still wonder what's going on there.
Thanks for all your help everyone, I am now on the way to trying to actually use the Ignitech to tune with now that I have ben correctly guided through the software compatability madness. That is a nightmare that should not be that difficult.
Cheers,
Mike Norman
G-Force Engine Development
