Thanks again..Cammo wrote:Don't forget to check the fuel tap vacuum line.0.S wrote:I changed the fuel line from the tank to the ‘splitter’ and this was very worn/soft/pliable indeed.
I then changed the fuel tank breather & drain hoses as both of these were worse for wear with cracks visible.
Good chance this is your problem if the hoses above were worn.
Changed the vacuum line too and took it for a short steady ride of about 25 miles and it didn’t cut out.
Plan a longer/faster ride once it warms up later today – fingers crossed.
