Yes pretty much, and when the bike pulls away from idle. It won't do any harm adjusting pilot screws, but I don't think it's responsible for your issue.lizard821000 wrote:surley the pilots only effect idel??
How many washers have you got under the carb needles? You can take one of the rear carb slide covers off without removing the carbs, worth a check if you can't remember.
Try 1 0.5mm washer (this is standard) and see how it runs, or if it has only 1 washer try an extra washer.
Hard to tell whether it's running lean or rich over the net!
