Could anyone confirm the components of the swing arm pivot assembly?
I think I'm missing a spacer, unless the bolts pull the frame in to it. I have a top hat type spacer on the left hand side but nothing on the right.
With nothing torqued up there is a few mm between the frame and the swing arm. Should there be something packing that out?
Swingarm Spacer NC30
Re: Swingarm Spacer NC30
Thanks. I've checked that but it doesn't confirm whether the frame is pulled in to close the gap or that play remains in the assembly
- Bike owned: ftr223 650 bros
The frame cannot be pulled in, it is a large casting.
The pivot bolt adjuster is screwed into the frame until it touches the s/a bearing then lightly torqued up [ 11ft/lbs] to remove all end play.
The pivot bolt engages with the adjuster so that a 14mm allen key can turn it.
That's exactly what I was trying to find out. Thanks
Then you should know that your are not missing anything. arsey30 has already answered the question on how to adjust the bolt.mrrowley87 wrote:Thanks. I've checked that but it doesn't confirm whether the frame is pulled in to close the gap or that play remains in the assembly
You can find this info and all the other torque figures in the service manual in the downloads section.
