Looking for replacement gaskets for my NC24, are they the same carbs on the NC30 and 35, ie can I use a kit from them?
Discovered the reason why the choke cable had snapped; the rear choke slides are sized solid!
NC24 Carb gaskets
- Bike owned: 01 B6, 89 NC24, 8X GPZ400R
Re: NC24 Carb gaskets
The gaskets between nc24 and nc30 carbs are mostly interchangeable.
The choke mechanism is different, the nc24 setup being a bit cruder as you've found!
Unfortunately Dave Silvers only had 1 gasket set left so 3 weeks later I've gotten a set from Japan!
I've been following the NC30 guide but have discovered my main jets are 3x 5 and 1x 4 and all have 115 jets. Also the head snapped off one of the pilot jets
Can someone confirm I should be running 115x4 up front and 120x5 in the rear and any advice about removing the pilot would be awesome.
I hope you didn't pay too much for the gaskets! High quality pattern replacement gaskets are available here (for nc30, will fit nc24) for a fraction of the price of orginals: viewtopic.php?f=64&t=42551Sasakura wrote:Unfortunately Dave Silvers only had 1 gasket set left so 3 weeks later I've gotten a set from Japan!
I've been following the NC30 guide but have discovered my main jets are 3x 5 and 1x 4 and all have 115 jets. Also the head snapped off one of the pilot jetsCan someone confirm I should be running 115x4 up front and 120x5 in the rear and any advice about removing the pilot would be awesome.
NC24 should have 115 main jets, 5 hole emulsion tubes in rear carbs, 4 hole emulsion tubes in front carbs and 35 size pilot jets in all 4 carbs.
If yours is different I suggest you source the parts to put it back to correct specification. Used parts are easy to come by (NC30 uses some of the same parts), just stick a wanted ad in the classified section.
You should be able to remove what's left of the pilot jet with a suitable pair of pliers, just go easy on it.
You should be running 115 all around for stock.Sasakura wrote:Unfortunately Dave Silvers only had 1 gasket set left so 3 weeks later I've gotten a set from Japan!
5 hole tubes in the back and 4 holes in the front.
Best use the VITON rubber gaskets made by litekblair, about 20 quid for all 4 carbs and they are ethanol resistant and will last along time.
Cammo is spot on.
No need to upjet it.
Thanks for the info, I have 115 all round at the moment which seems to be the first set of things that *are* right with this bike. Waiting on pilots from Rick O then I might be able to start putting things together again!
Yes don't go too much by the haynes book.Sasakura wrote:I hope you didn't pay too much for the gaskets! High quality pattern replacement gaskets are available here (for nc30, will fit nc24) for a fraction of the price of orginals: viewtopic.php?f=64&t=42551![]()
Seems odd your emulsion tubes are wrong, guessing it must have had some replacements at sometime and the person doing it didn't realise they were different.
