I always do this.porndoguk wrote:magg wrote:DIY impact gun, place ring spanner over nut and hit ring spanner with hammer. You will still need the screw in puller to get the flywheel off. If puller is hard to come by then a bolt of same size thread can be a substitute.
You need to 'Shock' the nut loose, not apply constant torque (unless you have the rear brake on.. in gear (i'd prefer 1st) AND a massive long extension..
Put it in gear / brake on.
Use either an extension handle and socket or a big spanner..
Make sure it is all a good fit else you'll strip the nut... with it secure (2 people job if you can't hold it all secure)
Give the hammer and extension bar etc a good few sharp blows with a hammer.. should shock it loose... as Rick said.. watch your hands!
Once the nut is out (14mm iirc) You'll need an M20 x 1.5 bolt to screw into the newly revealed hole to pop the flywheel off.. don't bother with a puller as they usually mark the flywheel and the bolt is all that is needed.
