RVF400 Project - A step in a different direction.
TZcRank
Reactions:
Re: RVF400 Project - A step in a different direction.
Post by TZcRank » Mon Jan 21, 2019 9:29 am
Thank you
ZippiT
Reactions:
Post by ZippiT » Tue Jan 22, 2019 5:36 am
More parts! Everyone loves parts! :D
Translogic Micro Dash
RVF400 HRC Oil cooler
CBR600F4i Oil cooler (replaced by above)
Stubby oil filter HF147
CBR600RR 2016 Forks
CBR600RR Tokico calipers
RoninZX-10R
Reactions:
Bike owned: NC35 racebike, ZX10R roadbike
Post by RoninZX-10R » Thu Jan 24, 2019 8:22 pm
That new front end will look so nice on the RVF. Can't wait to hear what the big bore motor is like to ride, that thing will fly!!
ZippiT
Reactions:
Post by ZippiT » Mon Jan 28, 2019 4:54 am
I can't wait either. Can't wait to take it through some twisties
RoninZX-10R
Reactions:
Post by RoninZX-10R » Tue Feb 19, 2019 7:52 pm
Have you been able to make any further progress? Really looking forward to seeing more photos.
ZippiT
Reactions:
Post by ZippiT » Sun Mar 03, 2019 8:22 am
Mainly gathering parts for the build. I've ordered the Carrillo rods from Mike, and should be here this month. Still need to get some crank/rod bearings, piston rings and modified head gaskets before I can start assembling the engine.
More things gathered:
NC21 sprocket cover
NC21 clutch slave cylinder (May upgrade it in the future)
NC21 push rod
RC19S clutch master cylinder
CBR600RR left hand switch-block
CBR1000RR right hand switch-block
RVF400 pillion pegs, to replace the VFR400 ones
VFR400 shock reservoir bracket
Full engine rebuild set
EBC heavy duty clutch
Engine casings bead-blasted
RoninZX-10R
Reactions:
Post by RoninZX-10R » Tue Mar 05, 2019 1:01 am
Looks like you've been spending a lot of time collecting bits! Have you had the cylinders bored out yet?
ZippiT
Reactions:
Post by ZippiT » Tue Mar 05, 2019 4:52 am
Yep, pics on page 1
Vincent
Reactions:
Bike owned: '89 NC30 T1, '92 NC30 T8
Post by Vincent » Thu Mar 07, 2019 12:52 am
What did you end up doing with the GP-T kit? Do you know if the fitment is the same (or similar) for a VFR400?
ZippiT
Reactions:
Post by ZippiT » Thu Mar 07, 2019 7:08 am
They do a GPT kit for the VFR. TYGA Make them. The tail is not a GPT kit piece tho.
