My non running 29
dunkenb
Regular Member
Bike owned: Cbr400rr nc29 type8 NSR250
My non running 29
Post by dunkenb » Fri Dec 30, 2011 3:55 pm
Well, i bought a 29 off flee bay a few months ago. Wasn't running and has loads of bits missing, an the bolt holding the front sprocket on was sheered off.( thank the lord for left handed drill bits! :grin: )
Finnally got it running today,connector to the reg/rec from the enine wasn't plugged in and the ht lead to number 4 cylinder wasn't in straight . Also stripped and cleaned the carbs and re-set the air screws ( they were all different! Lol)
Only prob i've got at the moment is the temp gauge (on the clocks i had to buy as there weren't any)
Dosen't move off zero. It moves slightly when the ignitions switched on but nothing after that.
Any common probs with these??? It all seems to be plugged in.
Cheers .
Davez29
Bike owned: NC29 forever
Re: My non running 29
Post by Davez29 » Fri Dec 30, 2011 4:37 pm
I know my temp gauge takes a while to move and even after a good warm up it only moves a small amount, I have to be out a while before it warms up enough to move upto the T in temp. The Haynes manual lists a few tests you can do on the cooling system.
dunkenb
Regular Member
Post by dunkenb » Fri Dec 30, 2011 5:21 pm
Cheers, i'll have a nose through the manual later ( xmas pressie off her indoors) :grin:
