NC30 Problem !
NC30 Problem !
i went out for a ride on my nc30 last night i had been out for 5 - 10min before i smelt a smauldering smell ( burning plastic). once i shot back home i realise that the wiring on the right hand side of the bike had melted reveling 3 wires. this was very close to a connection block. if you where looking at the bike from the right had side there is a screw that connects the fairings to the frame. the burn was about 3" below this. can anyone assit why?
just to much heat from the engine??
- leef82
- Bike owned: vfr400 nc30
Re: NC30 Problem !
are they 3 yellow wires?
Re: NC30 Problem !
i am unsure but possibly yes.
Re: NC30 Problem !
99% that it's going to be the Generator connector-block.. it has 3 yellow wires in it that comes from the altenator.
Test all of the charging system.
How old's the battery on the bike...?
- BillingCBR
Re: NC30 Problem !
isn't the generator on the left hand side on the NC30?
Re: NC30 Problem !
Yeah, the generator's on the left, but the wires go between the V of the engine to the right hand side where they connect into the rest of the wiring harness.
Re: NC30 Problem !
I am unsure. What do i need to test and what should i expect?
Re: NC30 Problem !
Re: NC30 Problem !
The plastic coating on the wires hafe burn off completley. would i be better buying a new wiring loop or just replacing the 3 wires? do u think it could be the heat of the engine if the wiring come though the middle of the V?
Re: NC30 Problem !
No it's an electrical problem.lazyboydobby wrote:The plastic coating on the wires hafe burn off completley. would i be better buying a new wiring loop or just replacing the 3 wires? do u think it could be the heat of the engine if the wiring come though the middle of the V?
Very common for these to burn out..
Check the altenator output with a multimeter.
Put the meter onto AC volts and measure between each wires at 5000rpm and see how many volts you have.
If this is ok, connect it back upto the reg/rec, after replacing the connectors and see what voltage your getting there.
How old is the battery?
