NC30 Problem !
leef82
Bike owned: vfr400 nc30
Re: NC30 Problem !
Post by leef82 » Sat Sep 18, 2010 10:25 am
its worth given all the connections a clean up, they get corroded and can cause a resistance which can cause things to melt and work, also i was told by the man who mot'd my bike ( ex nc30 owner) that its acommon problem that the connecter where the three yellows are melts, so one way to stop the resistance is to cut off the connector and solder the wires together, but youll probly be best checking the reg/rectifier and also the alternator first.
lee
lazyboydobby
Re: NC30 Problem !
Post by lazyboydobby » Sat Sep 18, 2010 11:01 pm
that was my plan. to cut both ends and replace the wiring with soldered connections. i should be able to check battery etc 2morro.
keep ypu informed
lazyboydobby
Re: NC30 Problem !
Post by lazyboydobby » Mon Sep 20, 2010 1:38 pm
i have followed the step by step guide to checking the electric's and yes i beilieve it is the recifier. It says stator or the guide does that mean the alternator or the recifier??
where is the best place to purchase?#
thanks
hardnutdvd
Regular Member
Bike owned: RVF400 NC35
Re: NC30 Problem !
Post by hardnutdvd » Mon Sep 20, 2010 4:55 pm
stator is the alternator and can be purchased here
http://www.electrexworld.co.uk/honda-ro ... 643-0.html
you can get a rectifier from most bike shops...standard
or you could go for the better one from an R6 (iirc)
do a search for rec/reg upgrades. its been written about more than any other subject on here!
lazyboydobby
Re: NC30 Problem !
Post by lazyboydobby » Wed Sep 22, 2010 9:48 pm
i have ordered a recitifier. how difficuit is it to fit?? it cant be as simple as just plugging it in surely??
leef82
Re: NC30 Problem !
Post by leef82 » Thu Sep 23, 2010 9:21 am
ist as easy as unbolting from the subframe (two bolts) and disconnecting the connector block, the only prob you might find is that the connector block might be melted, so you may have to cut the wires and fit a new connecter, you ll probly get one with the new reg/rectifer
lee
lazyboydobby
Re: NC30 Problem !
Post by lazyboydobby » Fri Sep 24, 2010 4:16 pm
by connector block you mean the block i was talking about previously. in the middle of the bike on the right hand side.
hardnutdvd
Regular Member
Re: NC30 Problem !
Post by hardnutdvd » Fri Sep 24, 2010 8:00 pm
yeah, its on the right hand side with three yellow wires. it should be one of the blocks that is located with a load of other electrical connector blocks...
mine was knackered so i cut the wires and put a new one in, make it a good quality one and solder the male and female connectors
he might have also meant the connector block that actually plugs into your reg/rec. check that too and make sure its not burnt/corroded
lazyboydobby
Re: NC30 Problem !
Post by lazyboydobby » Fri Sep 24, 2010 8:41 pm
can i not just simply solder the yellow wires and do away with the block??
leef82
Re: NC30 Problem !
Post by leef82 » Sat Sep 25, 2010 7:40 am
year i meant the connecter on the reg/rec , when i bought a new reg/rec i also got a new connecter with which then all i did was snipped the five wires ( the three yellow and two others) solderd the wires to the new connecters then pushed the five into the connector, then that connector plugs into the rec/reg
lee
