HELP!!! Before i kill my dad!!!!
Re: HELP!!! Before i kill my dad!!!!
Post by Drunkn Munky » Mon Mar 22, 2010 7:03 pm
zimm wrote:large torx bit, gentle tap, unscrew, done.
This works
fixer
Bike owned: nc30/bsab25
Post by fixer » Mon Mar 22, 2010 9:01 pm
When replacing plugs i push ashort piece of rubber tube over electrode end,with ashort piece of wood doweling in hose end.Locate in plug hole and turn in plug,any tight resistance would be taken up by the rubber hose so avoiding a crossed thread.Hope this is of help. :up:
F I X E R
richhemmings
Bike owned: VFR400 NC30
Post by richhemmings » Tue Mar 23, 2010 9:25 am
fixer wrote:When replacing plugs i push ashort piece of rubber tube over electrode end,with ashort piece of wood doweling in hose end.Locate in plug hole and turn in plug,any tight resistance would be taken up by the rubber hose so avoiding a crossed thread.Hope this is of help. :up:
? I dont get?
rubber tube over the threaded end?
I've always thought screwing plug in by hand was best, then just nipping them up with a wrench / screwdriver with socket?
I use the 13mm socket with an extender bar for my NC30 as the heads are well recessed, also, if you can get tehm, or make one up, my ol' man use to use a socket with a rubber or foam insert to hold the lug strraight - makes lining it up easier.
fixer
Post by fixer » Tue Mar 23, 2010 8:12 pm
Oops my mistake other end :oops: :oops: :oops:
F I X E R
Chris 91UK
Bike owned: 91 UK Spec RWB NC30
Post by Chris 91UK » Wed Mar 24, 2010 7:40 pm
PANIC OVER!!
the whole plug is now out!
stud extractor,,,,nice and slowly, came straight out in about two minutes which surprised me :o
so now i can talk to the old man again ( but it will be a while before he goes near the bike though!)
thanks very much for the advice greybikers,much appreciated ;) :peace:
w00dzy
Bike owned: Aprilia RSVR Mille
Post by w00dzy » Wed Mar 24, 2010 8:44 pm
Good stuff, bet that was a relief!
