Drilling Slide Advice / Pilot Screw Query.
Re: Drilling Slide Advice / Pilot Screw Query.
Post by Neosophist » Wed Oct 20, 2010 10:57 am
Yakama wrote: Does anyone know which NC24 carb slides have the curved bottom mentioned above as there are two different part numbers according to microfiche:
16111-ML0-724 & 16111-ML-0004
cheers
724 are a later revision and probably the only ones about.. there was a full set of brand new ones on ebay recently :O
Are you planning to order new ones as there 115 each IF you can get them 460 is awfully expensive.
superlite
Bike owned: TLS, LB80 x 2
Post by superlite » Wed Oct 20, 2010 11:16 am
RickOliver wrote:I`ve managed to get my hands on some NC30 carbs which have HRC slides and springs in them.Rick
After eagerly putting my hand up for some HRC slide springs, I realised that HRC don't have a part listed for slide springs for the NC30? At least, I can't find any part numbers? Am I dreaming here? I've had some very dodgy springs in HRC equipped carbs in the past - are the springs you have the the real deal Rick 8-) Please say yes :pray:
'Take it to the Back'
Yakama
Post by Yakama » Wed Oct 20, 2010 1:10 pm
cheers
I just want to know to see if I can source any cheap ones and also to see if its the early ones or later ones that are like the HRC slides.
Post by Neosophist » Wed Oct 20, 2010 1:47 pm
They should be both the same.. 724 means a revision over the base part, so not sure what was changed.
I'll have a look in the parts book later on see what it says.
Yakama
Post by Yakama » Wed Oct 20, 2010 1:48 pm
cheers
