NC-30 Shock Differences between years?
ScottieDucati
Bike owned: '89 VFR400R
Post by ScottieDucati » Mon Dec 14, 2009 8:51 pm
I'm wondering if there are differences in the rear shock (other than features, I'm talking length, spring rate, etc) between an '88 and '92+ NC-30? Looking to order a Penske and their book only has '92+.
Also if anyone has experience with an HRC type rear link, I was curious how that might affect the linear spring rate curve, if there are any changes aside from ride-height.
Thanks!
Re: NC-30 Shock Differences between years?
Post by CMSMJ1 » Mon Dec 14, 2009 9:09 pm
The physical sizes were the same for all the shocks - 1989 -1994
The 1989 did not have a remote res, the 90-onwards did.
Penske will sort you out.
There was a lad on here a while back, EddieHRCrider (I think) and he was on BARF too..he had a Penske on his moto..8895 model? That sound right?
ScottieDucati
Post by ScottieDucati » Mon Dec 14, 2009 9:36 pm
Which model makes no difference, Penkse shocks are all modular... mine has a remote reservoir but the bike says it's an '89... odd. Is the physical dimensions the same as an RVF too?
Post by CMSMJ1 » Mon Dec 14, 2009 9:37 pm
RVF top mounts are different...but regards length etc I am not sure. Think theya re the same,.
I use an RS250 shock that is 315mm (think) along with an RVF linkage and the rear is pretty high and works very well.
fastdruid
Regular Member
Post by fastdruid » Mon Dec 14, 2009 9:58 pm
IIRC it's 5mm different between RVF and VFR, shocks themselves are identical mounting but the RVF has a ride height adjuster on the top while the VFR bolts direct to the frame.
Druid
ScottieDucati
Post by ScottieDucati » Thu Dec 17, 2009 8:47 pm
Thanks for the input, ordered a Penske today :D
