Fuel tap
Posted: Sun May 31, 2009 1:44 pm
by topper
I can't decide if mine's broken. If the bike's idling and I turn it to Off, how long should it take to stall?
Re: Fuel tap
Posted: Sun May 31, 2009 2:06 pm
by jamie
It will still run for a bit as there is still fuel in the system not sure how long for but as an example i started my bike up and got a couple of hundred yards down the road when it cut out and i found that i had not turned the fuel on.
Re: Fuel tap
Posted: Sun May 31, 2009 6:05 pm
by topper
Hmm. I reckon my bike was idling for at least 5 minutes and still didn't conk out. I wonder if 200 yards riding uses more fuel than 5 minutes idling.
Re: Fuel tap
Posted: Sun May 31, 2009 7:17 pm
by challymo
I left mine off for a week then rode it, got 2 miles up the road before i noticed and even then it didnt conk out. Easiest way to check is to turn fuel tap off and then disconnect the fuel hose. If fuel still comes out then youve got a duff fuel tap.
Re: Fuel tap
Posted: Tue Jun 02, 2009 4:31 pm
Yup! good idea.
As dont' forget if its still connected and you turn it 'off' you have fuel in the carbs and all the way up the pipe to the tank, quite a bit :)
