Exhaust question
magsmagsmags
Exhaust question
Post by magsmagsmags »
I'm after a louder exhausts for my 3TJ, someone on here has a blueflame exhaust for sale which im interested in, but how will i mount it? i presume i'd need a link pipe from somewhere? or does the standard exhaust end can seperate from the link pipe?
Any help would be appreciated
Re: Exhaust question
Post by Evilchicken0 »
Hur hur ... he said he wants to mount it ;)
Sniggering apart ... yes the use a link pipe. If you've got the right link pipe you can mout the pipe straight on and the strap mounts to the pillion peg.
I had my link pipe cut and rewelded cos it left the can sticking out further than the back of the rear tyre.
It's best to take it to a dyno and have a run to see what the fuelling's like ... clean the carbs and air filter first and don't fall for them fitting a Dynojet kit. Chances are you can raise the needles if it's a bit lean.
