				diode
				Posted: Sun Apr 12, 2009 10:30 am
				by beefyvfr
				does anybody know where i can get a new clutch diode for my nc30..........
				Re: diode
				Posted: Sun Apr 12, 2009 1:08 pm
				by shaun1988
				*echo* *echo*
				Re: diode
				Posted: Mon Apr 13, 2009 9:03 pm
				by dixie24
				am i right in thinking this is the small piece sticking out from the loom near the
indicator relay,left side of sub frame?
if so i'm sure i have two of them.
i can check tuesday evening and get back to you if second hand is ok.
				Re: diode
				Posted: Tue Apr 14, 2009 5:44 pm
				by beefyvfr
				hi dixie if you could check that would be great......... it would be nice to know that iam actualy in neutral ,,,, lol
				Re: diode
				Posted: Tue Apr 14, 2009 6:17 pm
				by wullvfr
				beefyvfr wrote:it would be nice to know that iam actualy in neutral
are you now talking about the neutral switch?
william
				Re: diode
				Posted: Tue Apr 14, 2009 6:24 pm
				by beefyvfr
				no not the neutral switch, the diode at the rear of the bike near the rectifier which is part of the saftey curcuit and if the diode is not working properly the neutral light stays on ,when your in gear with the clutch in......the doide is only suposed to let the current flow one way but when you test for continuity a broken diode will show continuity both ways instead of one way.....
				Re: diode
				Posted: Tue Apr 14, 2009 6:31 pm
				by wullvfr
				i know what yer talking about now......i was getting confused with the talk about the clutch switch one minute then the mention of neutral
william
