heater gauge
Posted: Sun May 25, 2008 1:27 am
by weeman
hello all just wondering what to test and how, my heater gauge is not working right, when you turn the key on the needle moves but only a little bit, have tried another gauge and the same thing happens, would anyone think this could be the temp sensor if so how can you test it?
would be greatful for and advice
Re: heater gauge
Posted: Tue May 27, 2008 11:57 pm
by fourfingers
hi weeman.
I have read this in the nc30 WS manual, and should be the same for the cbr.
Testing of the temp gauge is as follows:
disconnect the thermosensor cable. turn ignition key on (no need for the engine to be running), ground the thermosensor cable to ani point of the frame. The temp gauge shoul go to "H". Dont keep the cable grounded, it will damage the gauge.
The thermosensor resistance should be:
130-180ohms@ 50ºC
45-60ohms @ 80ºC
10-20ohms@ 120ºC
hope this helps you out
Re: heater gauge
Posted: Wed May 28, 2008 6:59 am
by leopard_pagan
it can be one of 3 things.
gauge
temp wire
thermostat
test all 3.
