Another 3tj Hybrid Lives
				smemly
- Bike owned: FZR400RR 600 Hybrid
Hi All,
About 4 months ago i started on the path of creating yet another 3tj/fzr600r hybrid. Borrowing Ideas from many on this forum, i set about attempting to follow. Yesterday afternoon i was finally at the stage where i could put petrol in the tank and press the starter button. To my amazement after only a couple of attempts it spluttered into life, all be it on 3 cylinders.
A bit of russian roulette with the downpipes and my hand found which one wasn't firing and thanfully it was just the HT lead not seated on the plug properly, as so many before me have said, there is not much room between the top of the engine and the frame.
when the weather warms up a bit i'll spray the tank and top fairing, other than that it needs the time to complete a few bits and bobs and it should be ready for a couple of trackdays in the spring.
I just wanted to take the opportunity to thank all the people who have followed the path before me and posting their results, it really has been the incentive that has got me this far.
				smemly
Re: Another 3tj Hybrid Lives
Cool - bet your excited !!!
						- cagiva996
nice to see another newborn hybrid blinking its way into the world-nice one!
				dazzfr400
cool m8 you will love it when you get out on it even more so when on track annoying them so called hereos on big bikes ,there faces when you come back into paddock can be a picture,that they just been spanked by what they think a 400 it so funny.i had so much fun at cadwell and mallory on mine last year.good luck and all the best daz
				Marb
- Thieving Pikey Twat
That is looking very nice! Glad to see that the nosecone arrived in one piece!  :)
				smemly
Cheers Marb,
Nosecone arrived friday, felt like one of the last pieces of the puzzle.
One of the big things i've got to do is sort out the throttle cables, i'm using one 600 cable which doesn't work particularly well, at one point a whiff of throttle had the engine sitting at 9,000 revs until i hit the kill switch.
does anyone have any experience with venhill cable kits?
One interesting quirk that i had, was the rev counter running going between 0 and 8,000 revs on the odd occassion. Seemed to clear with the fuel switch set on reserve. I am running full 600 loom, ECU clocks, the only non 600 part is the 400 fuel pump. The 600 one had an extra wire, which i assume is for the reserve?
I'll try it again over the next couple of nights if i get a chance.
				Alex.
That extra wire byt he fuel pump will be the signal wire for the fuel level sensor in the tank.  The 3TJ has a green plug coming out of the tank, just connect this extra wire along with the ground from the fuel pump and it will stop this dance.
You will also get a fuel warning light on the dash when the level gets low, before you are on reserve!
i had a similar problem with my hybrid, but it was a broken sensor in the tank rather than a discomnnected one.
Alex.
Alex.
All of a sudden I found myself in love with the world,
so there was only one thing that I could do,
was ding a ding dang my dang a long ling long!
				smemly
Cheers Alex,
I'll wire it in this evening and try again.
				fzrtim
- Bike owned: FZR400 FZRhybrid FZR600 RSV1k
Welcome aboard the hybrid club. You will love it!
Just out of interest did you mod the airbox or junk it for pod filters.
Roll on the sunshine
