What bolt size or part ID fits the unused front engine mount?
Killogen
Post by Killogen »
Hi all,
I'm midway through fitting some R&G crash protectors to my NC30 but the supplied bolts don't fit the thread of the front engine mount.
To my knowldge these are redundant by default on the NC30 so don't appear on the part drawings.
Any ideas please on the thread size and pitch, or even better a Honda part number that fits?
Cheers :)
MadMotoUK
Bike owned: FZR400,600, CBR893
Re: What bolt size or part ID fits the unused front engine mount?
Post by MadMotoUK »
*Should* be M10x1.5mm the same as the other engine mounts.
Killogen
Post by Killogen »
MadMotoUK wrote: Sat Sep 11, 2021 10:36 am *Should* be M10x1.5mm the same as the other engine mounts.
Thanks MadMotoUK, when you wrote this I hoped it was the answer as the bolts in the kit are M10x1.25mm. But I've just checked if I can clear the threads with an M10x1.5mm tap and there was no way that was getting through. :|
However, opening the tap and die reminded me I have a pitch gauge. Wrapping blutack around a slim screwdriver to get an impression of threads from inside the mount let me measure them as also being 1.25mm pitch.
So the bolts in the kit from R&G should be correct, just the threads might need cleaning out. So an M10x1.25mm tap is on order.
Cheers :)
I thought the R&G Kit needed a spacer and didnlt mount directly on the cases??
There is a drill kit, and a non drill kit isn't there? I have had some of these on an NC before, but can't remember if I had them bolted directly - I sort of recall a long bar that took the loads ?
Was years ago mind..so I might just need the nurses to come and feed me some werthers...
MadMotoUK
Post by MadMotoUK »
There are still and non-drill kits, your memory is still working :lol:
MadMotoUK wrote: Tue Sep 14, 2021 9:16 am There are still and non-drill kits, your memory is still working :lol:
Thank the baby Jebus for that!
I was beginning to think that stinking of piss was normal.. :D
:rocks:
