FZR400RRSP Flat-Slide Carb Settings
- Bike owned: FZR400RR (3TJ)
So, I have an FZR400RR (3TJ-1) with a standard motor in need of carb service. I also have a set of 32mm Keihin FCR flat-slides taken from an FZR600. I thought that I might as well give the flat-slides a go on the FZR400RR since it is headed for the track. Does anyone know the Yamaha factory settings for the RRSP flat-slide carbs?
Re: FZR400RRSP Flat-Slide Carb Settings
I have a setup manual for a 3tj SP but it's for the CV carbs I think you're going to have to dyno it ... you could ask BDK Racing.
If your taking it on track with flatslides you're probably going to want the BDK airbox / tray mod as well then tune it all
