Nc35 starting issues- never ending issues...
Posted: Sat Sep 05, 2020 6:28 am
Ok so been slowly working on the nc35 as I get time on the weekends.
After doing a minor carb rebuild and started up the bike noticed that the bike was difficult to start and eventually when it did sounded rough and would have difficulty starting on.
After doing a bit of trouble shooting I figured I would touch the exhaust pipes to make sure all cylinders were firing and lo and behold the front two headers were cold while rear two were hot.
So here are the things I did thereafter. Need some advice and help to make sense of things.
I pulled the front two spark plugs. They had a little bit of oil on them, primarily where the threats were. Not a lot. See picture below.
Then I started checking electrical stuff. I pulled out there Multi meter and this is where I started to get really confused.
The Haynes manual started the following.
“Ignition HT coils
Primary winding resistance - 2.5 to 3.5 ohms at 20 degrees Celsius
Secondary winding resistance
With plug cap- 14.0 to 25 k ohms at 20 degrees Celsius
Without plug cap - 12.0 to 14.0 k ohms at 20 degrees Celsius”
And here are my readings of the cylinder coils and coils. Note coils were still plugged in to the cylinder coils at the time of reading and negative terminal was removed from the battery
Front coil reading at 20k ohms - 2.41
again at 2k ohms - 1.837
Front cylinder coil at 20k ohms - .84
Again at 2k ohms - .258
Rear coil reading at 20k ohms - 2.72
Again at 2k ohms- No reading (kept dropping to 1)
Rear cylinder coil at 20k ohms - .86
again at 2k ohms - .252
From what I can tell the only readings that seem to line up are the primary winding resistances and the coil readings at 20k ohms.
According to the manual the next step should be to take off the coil from the cylinder coil and measure that but I ran out of time.
In you your opinions can you guys make sense of the info? I wasn’t sure if I should be measuring at 20k, 2k, or 200 ohms on the multi meter. Those were the only options aside from 200k ohms.
Spark plug picture below:
Sent from my iPad using Tapatalk
“Ignition HT coils
