Choke Slide Broken at Carb - Repair??
hutchy
Reactions:
Post by hutchy » Sat Jun 13, 2020 11:15 am
I went to start my bike up last night, give it some choke and all the tension disappeared.
Had a look at the carb end and the plastic slide that is pulled by the choke cable has snapped due to brittle plastic.
Is there a temporary repair for this or a replacement part available? Also, what is the process for doing this?
Thanks in advance
mechannibalism
Reactions:
Re: Choke Slide Broken at Carb - Repair??
Post by mechannibalism » Sun Jun 14, 2020 6:16 pm
What model do you have?
hutchy
Reactions:
Post by hutchy » Sun Jun 14, 2020 6:29 pm
It’s a 1993 GSXR 400 GK76a, standard carbs
mechannibalism
Reactions:
Post by mechannibalism » Sun Jun 14, 2020 6:36 pm
hutchy
Reactions:
Post by hutchy » Sun Jun 14, 2020 7:03 pm
That looks exactly right, thanks.
Looking at that, does that simply clip on?
mechannibalism
Reactions:
Post by mechannibalism » Sun Jun 14, 2020 7:49 pm
If it's the same as the early models it slides in. Hopefully someone with a GK76A will chime in.
Hubbskiboy
Reactions:
Bike owned: GK76A 1994 and 1990
Post by Hubbskiboy » Fri Jul 03, 2020 9:45 am
Yes, mechannibalism is correct.
The plastic bracket just clips onto the metal slide bar.
I bought a brand new one when I rebuilt my bike, but I kept the old one as a spare.
You can buy it off me if you want it hutchy? It's a bit battered and discoloured, but it would still work.
Let me know.
Hubbskiboy
Reactions:
Post by Hubbskiboy » Fri Jul 03, 2020 9:48 am
It's in better nick than that manky one you posted a link to though! ;)
