				NC30 Fork strip
				Posted: Fri Mar 27, 2020 1:25 pm
				by socket13
				Looking for advice, started stripping the forks on my NC30,now at the stage where i need to remove  the bottom damper rod bolt, 6mm Snap on allen key socket, 12" breaker bar and all thats happening is i can feel the allen key beginning to twist, i ckecked the torque setting in the manual and it states 20nm, has this thing grown into the alloy? any tips as to best way to undo it?
				Re: NC30 Fork strip
				Posted: Sat Mar 28, 2020 12:51 pm
				by magg
				It screws into the damper tube inside the fork tube.  Quite often the damper tube rotates with the bolt.   An impact gun usually proves successful or a bar inserted into the fork tube that locks onto the damper tube can be used to stop it rotating.
				Re: NC30 Fork strip
				Posted: Mon Mar 30, 2020 6:15 pm
				by socket13
				Thanks for that, I managed to get one out but the other one rounded out, I managed to drill that one out so all is good, just need to send the stantions off for rechroming,
Thanks for your advice
