NC24 where to source replacement master cylinder lines
Johannes
Reactions:
Post by Johannes » Sat Jan 04, 2020 3:48 pm
I'd like to replace the lines from the front and rear reservoirs to the master cylinders. It seems that both Honda and Pattern parts are no longer available. Has anyone come across this before and solved it?
Thanks.
Faxe400
Reactions:
Bike owned: VFR400RH, VF1000RG
Re: NC24 where to source replacement master cylinder lines
Post by Faxe400 » Mon Jan 06, 2020 8:43 am
For front, I used some rubber fuel line (altough brake fluid is not simmelar to fuel). I had it with fitting diameter available.
LiteTekBlair
Reactions:
Bike owned: MC22, 3TJ1
Post by LiteTekBlair » Tue Jan 14, 2020 11:55 pm
Lots of people using Tygon 2375
Carb seal kits in viton & other parts
https://litetek.co
