NC30 charging probs
Posted: Sun May 26, 2019 12:09 am
Hi all,
I have this electrical problem with my NC30 that has been dragging on for a year now. I've tried all sorts of things but haven't solved it yet.
Here's the story.
About a year ago I start getting problems with my indicators not working. Having had that problem before and solved it by cleaning out the switch gear, I tried that again. No result.
Completely dismantling the switch gear again, to as far as you can possibly get it, clean everything, bend everything in place etc. It's better but not perfect.
It would mostly work fine at medium revs (4-6000), but when halted at traffic lights, on idle: sometimes it wouldn't work.
Then one sunny afternoon, while driving home from work, she cuts out on me while waiting for a traffic light. Completely dead battery. Starter motor is unable to start the bike. Have to phone the wife to come with jumper cables and screwdrivers. Wait for an hour. Jump start the bike and it immediately runs, drive home OK (25km) and hook it up to the charger.
Couple of weeks later same thing, at a different traffic light. Starting to get annoyed here and decide not to call the wife, push start the bike, it starts and I make it home. That was the last ride before winter.
Then after winter, first ride to work is OK. Second ride, indicator probs pop up again. Third ride: the bike cuts out on me on the way home 4 times.
Manage to get it push started every time but
What I have done so far after that:
- measured battery tension: 11.8V, so dead battery. But it's not an old one (one year), so charged it and 13.6V
- checked the ground from the battery (on the frame): absolutely spotless, so that's not it.
- measured tension on battery while engine is running: approx 12.5V, way too low. So figured bad rectifier/regulator. Honda ones are not good and expensive. After market will set you back a fair amount also, so figured I'd give the Aliexpress a go at 8€. Got it within 2 weeks. Needed only minor filing to fit to the bike. After placing, tension on the battery was up to 13.5V. Not the 14.5V I'd hoped for but better than the 12.5V I had. So happy faces.
- cue a couple of trips to work. Problems with indicator lights pop up again. Then one morning I'm only 10km from home when the bike cuts out again. Decide to double back home, after push starting, and take the car. It's not going to make the 40km trip to and from.
- Today I measured the generator. I got 0.1 Ohm on all the coils. AC voltage was around 30V when at 2000 rpm and would steadily go up to 42V at 4100 rpm. So that all sounds pretty good. The connector between the coils and the wires to the regulator/rectifier seem pretty, how shall I put it, cooked
Not melted but a bit brownish.
I've done some searching on the web and read a story of a guy with the same problem and measurements. For him it turned out to be the generator, even if the voltages were OK???
Is it true that taking off the generator cover draines the engine oil? Is the generator running in oil??? That sounds really weird to be, even if it's just because of the resistance of the flywheel in the oil.
It could also be that the cheap Aliexpress rect/reg is faulty. I read somewhere that an R6 item can act as an replacement. Is that true? If yes, any specific model or all models?
Any thoughts are greatly appreciated to help tackle this problem.
Thanks in advance.
Roger
Here's the story.
Thanks in advance.
Roger
