NC30 electrical fault
Posted: Wed Jan 23, 2019 6:22 am
Hi all
I've got a problem and have searched and searched before asking but can't seem to find this issue. Lights/indicators etc won't work, temp gauge goes on the spaz to hot (just like it does when grounding the sensor wire to check the gauge) and bike does not run. It will turn over but absolutely no sign of sparking up. Strange thing is on the side stand I can move the bars just a little or even just put gentle weight on the left bar and it will come right, temp gauge drops back down, lights will work and bike will fire up without any issue, however it can easily fall out of this "sweet spot". When I start it, if I can keep the revs up over around 6-7k i can ride it just fine but as soon as revs drop back down, boom, problem kicks in, coughs and splutters and struggles and then dies.
Hoping I've overlooked something simple here and someone can help. Seems like maybe some dodgy wiring is earthing out (could explain the temp gauge??) and causing this? Haven't got to really pulling things apart yet but I've pushed and poked and prodded every piece of wiring I can trying to get a reaction but nothing seems to make a change other than that slight tweak of the handle bars
Anybody have an idea what could be causing these symptoms, be it certain components or a section of wiring? Any ideas or help on where to start looking would much appreciated! Track day in 2 weeks need it running
