Full exhaust system installation help
Icemaestro
Reactions:
Post by Icemaestro » Sat Jan 12, 2019 3:18 am
Hi,
Pulled apart the hrc exhaust on my nc30 because it’s been leaking (suspect not on properly from the get go), and I can’t for the life of me get the two rear headers on flush at the same time, let along into the 2-1 connector. Does anyone have any tips to installing? Don’t see how removing the shock would help as it still has to go back in there? Pictures show left one (sitting on bike) in situ, is in the way for situating the right one as both want to occupy the same space, to be flush and then insert into the collector. Help as to what to do, tricks or order would be much appreciated. ImageImageImageImageImage
Icemaestro
Reactions:
Re: Full exhaust system installation help
Post by Icemaestro » Sat Jan 12, 2019 10:10 am
All good! Hours later, shock removed, noticed I hadn’t got the crush gaskets quite right centrex, and it had put the whole thing off a little.
Return to “V4 - Workshop”
