SOLVED - No power past 8k! Thanks to all, results are in and the next saga is on...
Posted: Mon Nov 19, 2018 10:19 am
Well thanks to all who contributed over the past year to the woes which was a basket case.
Finally budget and circumstance has seen another nc23 saved from the scrappers or eBay...
MOT has been passed and first ride of her at all took place the other night. And that is where the saga continues.
So it pulls a lot harder than I was expecting for a 400. At first I had an issue where I’d screwed up the de restriction but sorted that. Bike now will rev through the range however, above 8k it’s really laboured and will hardly pull through.
Drop down a gear and it’ll shoot trough to huger revs but then not pull any further.
Roll off the throttle and pause a little and it’ll recover but not with power to match the bottom end.
Headers all getting hot but number two cylinders header doesn’t seem as hot as the other two.
Thoughts are as follows...
Blocked main jets
Air leak somewhere, carb rubbers or box mounting
Fuel starvation from other means than jets.
Poss reg rec issue
It was a basket case and I’m pretty sure on rebuilding the carbs it was 110 mains and looking at a J carb sizing I think these should be bigger at 116.
Anyone any thoughts on diagnosing??
Thanks again to all. Couldn’t have got this far without the forum!!!
Matt
Blocked main jets
Poss reg rec issue
Matt
