Couple of questions
Posted: Thu Jul 26, 2018 9:46 pm
by nc30 duck
Hello all, realise I don’t post often, so apologise for popping up looking for help!
I have an nc30 r3n with twin stack Tyga system. I rejetted (120/122 I think) and replaced needles as per recommendation from rick Oliver. But after a dyno run to investigate poor response at 6-7k rpm it seems the bike is rich across the range but very rich low down.
Question is related to the cdi mod and what it actually changes!? I can see how to do it, but don’t understand what actually changes.
Cheers,
Matt
Re: Couple of questions
Posted: Thu Jul 26, 2018 10:54 pm
by RoninZX-10R
If you're referring to the 2.2K ohm resister that's installed in the orange/blue wire, it's used when the speedo has been removed for race bikes. If the resister isn't installed the ignition control unit restricts the amount of revs the engine can get to (I can't remember but I think it may stop once it gets to approx. 8,000rpm???).
Posted: Fri Jul 27, 2018 4:14 am
by magg
As RoninZX-10R says Ignition mod allows full engine revs if the speedo is removed, otherwise mis-fire occurs at approx. 5000 rpm. Would suggest you just rejet to suit the engine's current mixture requirements. Any changes to exhaust/fuel system can have an effect for better or worse.
Posted: Sun Jul 29, 2018 4:28 pm
yep yep.. get it jetted to suit, the igniton box "mod" just cuts the speeo restriction as been already mentioned, doesnt do anything else.. you dont even need that resistor either you can just join the wires toegher.
