Nc30 left switchgear, relay mod and loom advice/identification
Posted: Wed Jul 18, 2018 7:51 am
Hi all, keen on advice around my left switchgear on nc30 as well as my nc30/35 project. 400gb seems to be down!?
1) I did the low beam relay mod a few years ago with no issues, just clamped it on. Went to go solder properly about 6 months ago and low beam wouldn’t work. Had another child and so time disappeared and here I am. On checking now, reverting to stock the low beam still doesn’t work. High beam and park lights fine. When I bypass the switch (by connecting lights to black/red white) low beams work. Am I right in saying my switchgear must be gone? Looking inside it looks okay I believe, is there anything I can do with the existing gear? I wouldn’t mind just wiring it to always on if I can do this through the relay. Also keen on advice as I can’t remember the order for the wires! Have attached my current plan - hard to tell when my relay doesn’t have the expected numbers on it.
Second query - I have a project where the plan is to build an rvf that has an nc30 engine, loom, cdi, coils and carbs, everything else rvf (as it is a nightmare getting rvf things in this country and I had some spares). However this loom looks a little odd to me - looks like the nc30 cdi connects up no issues, but (when I was looking to try the spare switchgear I had) noted the ‘nc35’ switchgear that came with the bike has an odd plug on the bottom - can I confirm this is a switchgear from an rvf? And could I reword for the nc30 and what wires do what/how do I do this? The other weird thing is I can’t find the plugs on the supposedly nc30 loom that I would expect to connect to the switchgear!!? Can anyone shed some light on this for me?
