Worn loose gear lever
Posted: Tue Jul 17, 2018 8:01 pm
by slug675
The gear lever on my NC30 is worn and has a lot of sideways movement on the shaft ( as has the rear brake ). A new lever is about 100 euros which is a bit rich for me. Has anyone repaired their lever? Can a bearing or bush be used? I also want to replace the rod ends. I have read somewhere that these are riveted on and can be easily replaced.
Re: Worn loose gear lever
Posted: Wed Aug 15, 2018 8:11 pm
by slug675
Sorted most of the problems. Gear lever much better now, even getting neutral seems easier. I replaced the rod ends with new ones i got from McGill motorsports for about £17. M6 x 1mm female rod ends, one left hand and one right hand thread. They are physically slightly bigger than the originals which were completely shot, but fit. Drilled and punched out the old ones from the back then bolted on new ones with a small spacer between rod end and lever so they are as the originals.
The other part that was worn was the main step bracket. This was quite worn and was responsible for most of the sideways movement of the lever. Honda part number 50612MAS000, available still as used on many different bikes and cost around £18. There is a bush inside the lever which if replaced would probably remove even more of the movement but not got round to finding one yet.
Posted: Thu Aug 16, 2018 10:24 am
by Dynamohum
Well done let us know if you can source the bush for the gear lever .
I usually peel back the rubber covers and regrease the ball joints on the linkage rod which helps have multiple footrests and levers kicking around and are all worn and sloppy in same manner i would suspect its the bush that wears rather than peg .
Posted: Thu Aug 16, 2018 7:01 pm
by slug675
I would agree that the bush should wear first but on my one the bracket part had a visible groove worn into it. This probably means the bush is well past it too. I imagine the bush is a press fitting and may be a bit problematic to remove, but would only need to know the internal and external dimensions to find one on the internet. That will have to wait for a while though.
The rod ends are lined with teflon and kevlar so no need to lubricate ever again.
Posted: Thu Aug 23, 2018 6:56 am
by slug675
Dynamohum, any chance you could measure the external diameter of the bush on one of your spare levers. I only have the one lever and its attached to the bike.
Posted: Thu Aug 23, 2018 10:03 am
by Dynamohum
Will dig one out at weekend.
Posted: Fri Oct 05, 2018 9:05 pm
by alexandervf
A late reply....but still a reply
Bushing dimensions for brake pedal.
internal D : 17mm
Outer D : 19mm
Length : 18mm
This is what type of bushing the brake pedal has inserted,
And this is what type of bushing the gear pedal has inserted
This is something very close to what we need.
Since this is something i've been looking for as well, i have spent a good amount of time searching all over the web for a bushing replacement.
Brake pedal for starters.
Searching with the large bearing producers like SKF, KOYO, FAG, i have come to a conclusion that they do not have this type of bushing or they do not have the desired dimensions.
If someone else, has a clue to where we can source this type and dimension of bushing, may share it with us.
any other opinion is also welcome
Posted: Mon Oct 08, 2018 9:04 pm
by newtothis
Little end bushes might be worth a look. 17 or 18mm is a normal sort of gudgeon pin size.
Possibly OHV engine rocker bushes
Posted: Tue Oct 09, 2018 8:01 pm
by slug675
http://nwb.uk.com/bearings/EGB1718-E40-Bush.html
Not quite what you wanted but its not under much stress so it may be useful. It does say catalogue suspended but might be worth an email.
Posted: Mon Nov 05, 2018 3:09 pm
by dgunthor
i've got a lathe, so could make one up
