NC30 CARB INLET RUBBERS
Posted: Sun Jun 17, 2018 12:01 am
hi guys-- had the carbs off/separated(nightmare joining back together again on your own with only one pair of hands)serviced the carbs and replaced ALL the gasket seals and o rings(reason for separating the carbs was to change the seals and washers on the pilot jet screws which you can`t get to without separating the carbs into single units) with a LITETEK KIT from Thailand containing all the carb seals including float bowl gaskets all manufactured to exacting tolerances in VITON which is not affected by the ethanol in modern petrol as opposed to original NITRILE rubber seals which compress and over time crumble or split leaving you with float bowls that piss fuel everywhere which is the reason I removed the carbs also the bike Had been standing for 3 years.Job was fiddly, seals were exact facsimiles and when filled with fuel and left 7 days on the bench all carbs were as expected bone dry without a damp patch and the kit was only £22 with free postage !!
If you are gonna be brave and attempt to separate the carbs don`t expect any useful info from the Haynes manual--it might just as well be telling you where the nearest chippie is and the pics are not distinct enough to give you exact assistance--bit suck it and see--photograph every bit as you dismantle.
RIGHT NOW I`VE BORED YOU ALL TO TEARS WITH A LOT OF BLURB HERE`S THE REASON FOR THE BLOG:-------
I bought and fitted new carb rubbers FROM eBAY which were Chinese manufacture(OEM NO LONGER AVAILABLE) and trying to force the four carb stubs into the seals is giving me more than a bit of grief--not the easiest thing to do as you cannot see where you are and have to go purely by feel so------------
my question is,any suggestions as to a lubricant I can apply to the inlets that will ease them into the rubbers and will dissipate quickly without remaining as a lubricant making the carbs loose when the clamps are fully tightened--(please no mention of Fairy liquid or KY jelly please).
The best I can come up with is what I use to fit handlebar grips on with which is automotive paint prep degreaser but not sure if it will affect the rubber these inlets are made of not being oem material--any thoughts ??
Answers on a postcard to-----------------------------------
