NC30 starting/fuelling
Posted: Sun Aug 06, 2017 10:45 pm
I've lived with this issue for years and maybe it's time to look for a fix. My '91 NC30 is a Japan market bike with the only mods being an M4 slip-on can and Rick's stage 1 jet kit (2007) and starter/coil ground wire kit. When starting cold on full enrichener/choke and no throttle it always lights up, and then falters and dies after a couple of seconds like it's not getting fuel. Second try it nearly dies again but then seems to recover and run. Warms up quickly and always starts when warm. I was surprised when I installed the jet kit and cleaned the already clean carbs, that the problem didn't go away. The ground wire kit didn't fix it either. New plugs the same. Runs great otherwise. My notes tell me I have #35 pilot jets installed, and none came with the kit - should I try going bigger? Haven't tried more than 2 1/2 turns out on the pilot screws.
Alan
Alan
