Exhaust SS BOLT removal
Posted: Thu May 18, 2017 9:12 am
				Hello all,
My wifes' GSXR400 GK73a has a blowing exhaust gasket that I wish to replace. Also, I would love to change the oil and filter. Alas, it has a full Yoshi system fitted that makes the servicing look a little fun (not impossible) without removal first - and seeing as the gasket/s is/are leaking I would gladly kill two birds with one stone.
I'm an ex rally team mechanic so I'm not shy with tools, brutality and cursing at stuck parts.
The exhaust was bolted on (not by me) with (I think) M8 stainless steel cap head bolts. I've shown a couple of the easier to look at bolts my hex socket, extensions and ratchet etc but I can clearly see that they are twisting in their shank and will shear long before coming undone.
Has anybody else played this game and won?
One thought was to remove the fairing and spray the bolts with PB blast after every journey. But all of my previous experience has been if its seized the penetrating oils are too late to help. Plus gravity isn't helping me with that. Another thought was to get it hot, then using more heat localised and hope (ally heat and distortion not great for HG's). Or a less desirable course of action would be to shear them, remove exhaust and weld nuts onto the remaining exposed sections of shank and hope the heat from welding allows them to free up.
From there I'm getting despondent with thoughts like removing engine and replacing the cylinder head.
Cheers,
Glen.
Cheers,
Glen.
