VFR400 Replacement Valve Shim Calculator
DarrenIOW
- Bike owned: 1992 Honda VFR400 NC30
Hi,
I have made a VFR replacement shim size calculator in the form of a spreadsheet. Basically you put the valve clearance, Existing shim thickness measurements, and the desired new valve clearance figures in and it shows the desired replacement shim size in the final row of each column !
Also a reworked version of the printable sheet for writing down clearances in the workshop !
Not sure if they could be made available in the document library or can I just post them for download myself ?
Regards
Darren
Regards
Darren
- CRM
Re: VFR400 Replacement Valve Shim Calculator
Darren, what type of file is it ?
