NC30 wont turn on?
Posted: Wed May 10, 2017 4:47 pm
by Stockko
When I turn the key the bike won't turn on, no lights, nothing...
Fuses & battery are good also checked the wiring from the ignition leading up to the battery which seems fine.
Any ideas on what could be causing this?
Re: NC30 wont turn on?
Posted: Thu May 11, 2017 3:04 pm
by Ozzibiker
If nothing is working, then the problem must be early in the circuit. If not the battery or fuses, then most likely the ignition switch.
The fuse box is after the ignition, so if power is getting to the fuse box, it's not the ignition. Possibly a connector after the box.
You'll have to get a multimeter and circuit diagram and check what wires have power.
Sent from my Nexus 7 using Tapatalk
Posted: Thu May 11, 2017 3:15 pm
by magg
You might check the fuse in the starter solenoid.
