Clutch tip for Haynes users-newbies
Posted: Sun Mar 19, 2017 10:27 am
Hi, I know that many here will have done clutch changes but im sure some will be thinking of doing this for the first time. Im with the latter and have just done my first clutch plate change.
So while its fresh in my mind I will give a couple of tips for cbr owners who would welcome this and a laugh for those in the know.
Following the Haynes for removal is pretty straight forward. One thing I had difficulty with is loosing that centre nut. With having no special tool and on the side stand I tried keeping the bike in gear and pressing the rear brake, all that achieved was a spring effect while the chain loaded up and the bike trying to move forward. With a second person on the brake and me concentrating on the damn nut the same was happening.
What we ended up doing was the second person actually lay across the back seat adding weight to the bike while pressing the rear brake with his hand, this extra weight enabled me to crack the nut off in seconds. Worth doing first if your unsure but remember to open the chiseled part on the nut first.
When you come to put a new nut on use the same method and it will torque up no problem.
The better tip I can give is when following the Haynes about adding friction and steel plates is dont do it the way they say, honestly i was on ninety minutes and going no where as i just could not keep them in place and wiggle the centre part of the basket on to the centre spline, it seemed impossible and my bent legs were giving up on me by that time.
I actually done the obvious, although it took me a while before the penny clicked. I fit the plates on to the inner part of the basket with the groves and added the rear plate. This gave a semi sealed unit I could slip into the basket without the hassle of everything not lining up.
Now it is possible to fit it this way but I added one more thing to temporarily keep everything together for an easier fit, I found a small piece of flat plate with a hole in it and used one of the bolts from the four posts, this allowed me to add a small clamp finger tightened to a post across the outer part to keep the back from dropping off while fitting it. Then its easier to slip into the outer basket and onto the centre spline as your concentration can be kept to this main part.
If you have the bike on a Abba stand by then you can rock the back wheel very lightly to help with centering the spline onto the basket, it should just push on with a push or two.
Finally remove the temporary flat plate and spin the centre nut on. That method literally took 5 minutes to do.
Feel happy again.
Feel happy again.
