Can i replace CB1 cdi with CBR400RR racing cdi unit ?
Posted: Mon Feb 20, 2017 9:57 am
by podmanvn
Hi everyone,
I m new here, i have a CB1 model 1990. My CDI unit have some problem with rpm output (dead rpm line), so that i searched around ebay then found some racing CDI units: a superchips CDI unit (with UK flag) and EK2 HRC cdi.
Both of it from CBR400RR 1991.
I know that my CB1 and CBR400RR have same machine type (NC27 vs NC29)
When i plug they on my CB1, EK2 doesn't work, but Superchips CDI works. However, the bike have a limit sound when reaching 5000rpm.
Can u help me about this problem ? Or can u send me a CDI's diagram of them ?
Thank for help :)
These CDI: cbr400rr
Re: Can i replace CB1 cdi with CBR400RR racing cdi unit ?
Posted: Mon Feb 20, 2017 10:44 am
by royster81
I'm not overly familiar with the cbr400s but I know with the VFRs if you remove the speedometer the bike cuts the revs to 5000rpm, maybe with the superchips cdi it's something similar.
Posted: Mon Feb 20, 2017 2:59 pm
by CB1pod70
Not sure about the NC29 but I do know that you can't fit an NC23 CDI on a CB-1. The CB-1 has 1 pick up in the left hand engine cover but the NC23 has 2 pick-ups so the signal generated will be different.
I do have a spare CB-1 CDI if you need it or you can fit the NC29 engine cover to give the correct type of pick ups.
Posted: Tue Feb 21, 2017 5:36 am
by podmanvn
Can someone give me the instruction/manual for these CDI's Pins ? They have 16 pins connected, i think they have some different connections.
My CB1 still have speedo metter connected sothat i don't think that caused problem to rev 5000
I found this instruction, but don't know what is it used for ? Can u help me ?
http://www.400greybike.com/files/NC29%20Res%20Mod.jpg
Posted: Tue Feb 21, 2017 10:30 am
by iansoady
That mod is to disable the speed restrictor standard on Japanese registered bikes. It fools the CDI unit into thinking that the maximum preset speed isn't exceeded.
I'm not sure that's your problem however unless there is a constant signal from the speedo telling the CDI that you're exceeding that limit.
Posted: Wed Feb 22, 2017 2:42 am
by podmanvn
I'm replace original speedo with Daytona digiatal speedo which read from "digital eye magnet" place on front disc.
Maybe that cause problem.
Because of that, i need a map of connected PINs on this CBR400RR CDI. Could u help me ?
Posted: Sat Feb 25, 2017 4:21 pm
by podmanvn
Can someone help me please
Posted: Thu May 11, 2017 12:39 am
by amorti
Does sound like the limiter is your problem.
There is an orange wire with blue stripe in your cdi plug. It needs to see +12v for the bike not to limp. So get 12v from anywhere else and feed it in. Done!
