Page 1 of 2
Found a PCB behibd the clocks...derestrictor???
Posted: Sun Nov 30, 2008 5:55 pm
by Alfminator
Has anyone seen this before?
While taking off all the plastics of my new NC30 I found a little plastic bag with this inside. The whole thing was "water-proofed" by a bit of electric tape wrapped around the opening of the bag over the cables!!!
The wires go to a connector under the clocks with wires of the same colour disappearing into the main loom.
Looks like an HSC original part (Honda Shed Corporation) :D
What I can't understand is that, if a simple resistor can derestrict the bike, why all the extra components in there
Re: Found a PCB behibd the clocks...derestrictor???
Posted: Sun Nov 30, 2008 6:17 pm
by wullvfr
is that not all the components that are part of the switch that when the needle reaches 180kph the bike misfires as it runs on two cylinders?
im sure that just removing it from the speedo simply stops the switch from being triggered meaning it can go past the 180kph........the reason it was wrapped up would be to stop water getting in and causing it to probably run on two cylinders at around the 5000rpm mark!!!i have heard this being called "limp home mode"
so i don't think anyone has added any de-restriction mods but simply just removed the switch from the speedo!!!!!!
i may be wrong though
william
Posted: Sun Nov 30, 2008 6:19 pm
by wullvfr
looking at the picture more closely i think i am wrong...ah well!!!!!!
william
Posted: Sun Nov 30, 2008 7:43 pm
by Jon
wullvfr wrote:looking at the picture more closely i think i am wrong...ah well!!!!!!
william
I think you are right, the two blue bits are the "switch" that the disc runs between.
regrads
jon
Posted: Mon Dec 01, 2008 9:09 am
by DAC
Yes that is the de-restrictor method described on this forum a long time back.
I did it to my bike about 8 years ago and haven't had any problems since.
Regards,
Dave.
Posted: Mon Dec 01, 2008 12:15 pm
yeah don't worry about it, you might wanna ziptie a plastic bag over it to stop it getting too wet.
Don't cut it off though else the bike will missfire above 5500rpm's
Posted: Mon Dec 01, 2008 12:47 pm
by DAC
Neosophist wrote:
Paint?
Regards,
Dave.
Posted: Tue Dec 02, 2008 9:00 pm
by Alfminator
Sorrry for my ignorance,
Do you mean that people remove the whole circuit board from the speedo housing and leave it hanging behind the clocks?
I topught that there is some kind of tab inside the speedo that you can bend or cut and that would do the same job without risk of water playing up with the circuit board
Am I missing something?
By the way Dave. the rlaboratory sent back the results and the red paint splodges are HRC flaming Doohan red... gives the bike an extra 30hp. Either that or blood from the previous owners grazed knuckels!
Posted: Tue Dec 02, 2008 10:42 pm
by wullvfr
Alfminator wrote:Do you mean that people remove the whole circuit board from the speedo housing and leave it hanging behind the clocks?
your not missing anything at all.......well i don't think so anyway
there was a page dedicated to all the different ways of de-restricting the 180kph restriction......im sure someone will be able to give you a link to it,i seen it the other day but can't remember where.
william
Posted: Wed Dec 03, 2008 8:45 am
by DAC
Alfminator wrote:By the way Dave. the rlaboratory sent back the results and the red paint splodges are HRC flaming Doohan red...
Sorry Alfminator, my comment was a diversion aimed at Neosophist, who is trying to get some paint details for me.
William is right about the information that used to be here, though it was in the last century. If I powered up my old computer, I may be able to find it, but the aim of the modification is to prevent anything passing between the two pillars on the PCB sensor. So bending the tab, or re-locating the PCB achieve the same result. There is also an extra box which can be fitted externally, or the 'Resistor' mod, etc, etc.
Regards,
Dave.
