nc21 nc24 antidive forks
Posted: Sat Nov 12, 2016 9:15 pm
Here is my problem
I have a 1986 nc21 with non antidive forks and 275mm discs, i purchased a pair of antidive forks off what i hear was a 1987, when i came to fit them after changing seals and all, the callipers wouldnt line up with the disc and were approx 20mm off from what i presume was the calliper mounting bracket.
I purchased another pair of forks that had terrible pitting so im even more stuck in the suspension problem, do you know if i get hold of some of the mounting bracket from the 255mm disc that i will be able to solve the problem and have my 275mm discs lined up?
Do nc24 forks fit straight on the nc21 wheel/callipers and all?
Or are you any other forks that would bolt straight on with not alot of work? or stanchions i can get? or just any sort of inforation that you think might help...i've had a leaking seal for a while and this problem has just cost me way too much :/
