Tachometer problem
Posted: Sat Oct 15, 2016 1:16 pm
Hello all not been on for a couple of years but have decided to get the NC back out
Main issue tacho not working
I have a too small tacho that works of the coil wire but I can't see this
Standard tacho off coil wire only reads about 1/4 actual revs
Standard tacho off Ecu will not work
Ecu wire is giving off 5v when running
Tacho was of gf racing and works in a fashion off coil wire so I will assume tacho is good
Is they a way to get it to run correctly off coil wire or what is wrong with Ecu
I will no doubt have many more issues in the coming weeks
