NC35 Exhaust Rot query
Posted: Fri Oct 07, 2016 9:10 am
Hi all
Started my winter project NC35 semi restoration (more of a re-commissioning hopefully, but we will see what that throws up), so taken exhaust off to get better access to shock & linkages and the 40mm or so slotted section that the downpipes fit into beneath the clamp has rotted away, probably on both but definitely on one side. I imagine this will have been encountered before and wondered if there are there suggestions to sort/work around as a fix, as apart from that the exhaust just needs a clean up. thanks
