Oil pressure switch missing connection/Neutral bulb stays on
Posted: Sat Aug 27, 2016 3:11 pm
by Sbonett
Hi all, so I noticed that the oil pressure light doesn't ever come on, so I began looking and I noticed that the blue/red wire isn't connected to anything. Any idea where this should go?
http://imgur.com/a/2EaV8
Also any idea why the neutral light stays on even though in gear?
Re: Oil pressure switch missing connection/Neutral bulb stay
Posted: Sun Aug 28, 2016 12:35 pm
by LITTLE=ONE
Oil pressure switch is under the carbs on the top of the engine
Posted: Sun Aug 28, 2016 1:12 pm
by Sbonett
LITTLE=ONE wrote:Image
Thanks for that one. Any idea regarding the neutral bulb? I noticed that when I put the kickstand down and put it in gear the bulb turns off as it should, but once i raise the side stand it comes on again.
Posted: Mon Aug 29, 2016 9:36 am
by LITTLE=ONE
Here is the neutral switch , green and red striped wire
Posted: Mon Aug 29, 2016 11:32 am
by Sbonett
Any idea what may be the cause? Before I had cleaned the chain, all was working fine. Must have been when I removed the front sprocket cover.
